15 years agoCreating external SRAM pin assignment?
Cyclone IV GX How do create an external SRAM pin assignment? The SRAM is 512K x 8. The SRAM has - Address A[18:0] - Data DQ[7:0] - OE output - E chip enable - W write enable ...
15 years agoThe top level file is the "main" file for your design, whose I/O signals will be mapped to actual pins.
Eventually, you will be instantiating your SOPC within your top level file. I like to start by writing an empty top level file, which just lists the I/O signals so I can perform pin assign. But using the pin planner to assign pins and then have the pin planner create an empty top level file also works fine.
