15 years agoCreating external SRAM pin assignment?
Cyclone IV GX How do create an external SRAM pin assignment? The SRAM is 512K x 8. The SRAM has - Address A[18:0] - Data DQ[7:0] - OE output - E chip enable - W write enable ...
15 years agoDaixiwen,
I've started the pin assignment backwards, noice mistake. Using pin planner to already assign some of the pins. To create top level design file, pin planner has two icons "set up" and "create". I'm hoping top level design file is the same as the header file (?) will see. If all works out will switch over and work through your process. Finding the pin assignment guidelines can be very tricky with lots of got-ya! Good design check .pin file vs schematic suggestion.
