8 years agoCreate own Avalon MM-Slave
Hi there I'm trying to create my first Avalon MM-Slave which should be accessible through a NIOS II softcore. In the end I just want a MM-Slave which has a conduit input and output for connecti...
8 years ago --- Quote Start --- What is the data width of the master? If it's 32 and this component is 16, this is where the issue may lie. --- Quote End --- I had some time now to modify the slave for 32-bit read and write data. Now it works. Address is now correct and I'm able to read and wirte to the slave. Thank you very much for the hint!
