8 years agoCreate own Avalon MM-Slave
Hi there I'm trying to create my first Avalon MM-Slave which should be accessible through a NIOS II softcore. In the end I just want a MM-Slave which has a conduit input and output for connecti...
8 years ago --- Quote Start --- Assuming you created this as a custom component using the Component Editor, what are your settings on the Signals & Interfaces tab in the Component Editor for this slave interface? --- Quote End --- Yes, I did create the custom component in Qsys. You can see the signals setup in the attached component_setup.jpg picture. I did also attach the components .vhd file. Maybe I also did something wrong with the component itself!?
