8 years agoCreate own Avalon MM-Slave
Hi there I'm trying to create my first Avalon MM-Slave which should be accessible through a NIOS II softcore. In the end I just want a MM-Slave which has a conduit input and output for connecti...
8 years agoAssuming you created this as a custom component using the Component Editor, what are your settings on the Signals & Interfaces tab in the Component Editor for this slave interface? You may have set something that is affecting the address translation through the interconnect.
