8 years agoCreate own Avalon MM-Slave
Hi there I'm trying to create my first Avalon MM-Slave which should be accessible through a NIOS II softcore. In the end I just want a MM-Slave which has a conduit input and output for connecti...
8 years agoI doubt it would make a difference, but what happens if you use just IORD and IOWR instead of the 32DIRECT commands you used?
Also, in Qsys (Platform Designer), what have you set as the base address of this component? And since you're using Signal Tap, what does the address look like on the master side instead of the slave side? Maybe there is some weird address translation or something going on here.
