18 years agoCRC of jumbo frames
does any body know how is the CRC of jumbo frames (in Gigabit Ethernet)of size greater than 9K is found? What algorithm is used for that?
18 years agoWhy do you assume there is any difference to the commonly used CRC32 for Ethernet?
Accoring to Ethernet Spec the FCS is the same. What you have to keep in mind though is, that in case you are using half duplex with frame bursting, the FCS is followed by extension bits during the interframe gap, then the next frame begins. Hope that helps. Lokla
