14 years agoCRC Calculation - VHDL
Hello to all forum members!!! I'll be glad to get your's suggestions to solve my problem. I am interested to make the CRC Calculation as fast as possible (without using the MegaWizard function)...
13 years ago --- Quote Start --- How many bits do you receive in one clock cycle? I would compute the CRC with this number if bits in your case. Lets say you receive 8 bits per clock cycle, this would results in a much smaller logic and meet your timing target easily. --- Quote End --- The number of bits dependent from what side do you want to look - transmitter or receiver. * During transmission I get all the packet during one cycle time. One more cycle for CRC calculating and then I enable the transmission. After this I'm waiting the nest 10mSec to transmit another packet. * During receiveing I get the bytes one by one. If i'll separate the action on steps (step = one byte calculation). So I need something like 53 cycles to get the result. how can I use the pipeline for it? Or maybe onother one method the get the right results with minimum of actions. TNX
