ABaha5New Contributor6 years agoCRC-32 or others What is the time to process the CRC for a packet 1500bytes? Does the time same in a router or switch?
ABaha5New Contributor6 years agoWell, Wich is used in regular routers/switches?is there a difference regarding calculating the CRC?Many thanks.
Recent DiscussionsCyclone 10LP + EPCQ64A config flash corruption during power OFFAltera USB blaster not loading due to Windows 11 security setting[Arria 10 SoC] QSPI Flash GigaDevice Compatibility (GD55LB02GE / GD55LB02GF)Inquiry Regarding Clock Inversion as a Countermeasure for DPRAM Bit Errors on MAX 10HoRS issue consultation for EPM7128SQI100-10N
