15 years ago
CPLD MaxII, pull up resistor and led
Hello
I have to drive 26 Leds through the CPLD MaxII.
I have seen that this CPLD have internal pull up resistor that can be enable or not and apparently we can choose their value.
My question is: can we use those resistor for current limitation?
    The maximum forward current is 50ma. I will use PWM to drive the LED.
    Do you think it is ok for multiplexing.
    I don't know what is multiplexing and how to do that in the CPLD, I am a begginer. I will check that (but if you want or have time to explain feel free :)).
    The other proof that I am a begginer, is that I didn't know what was a common chip resistor (I've already check).
    Thanks for your help
    If you don't need high average LED currents, multiplexing the LEDs in a matrix can save output pins and resistors. Using common chip resistor arrays, 26 shouldn't be a problem, however.
    Ok thanks.
    So have you any idea to avoid the use of 26 resistors?
    I think about implementing a led driver in the CPLD but I'm not sure that it will decrease my number of resistor.
    --- Quote Start ---
    --- Quote End ---
    No, they are fixed. Output drive strength can be selected low or high. But you'll normally need external current limiting resistors to set the current of connected LEDs.
