11 years ago[CPLD MAX 10] Connecting the internal oscillator clock to the input of PLL
So I wish to utilise the internal oscillator of the CPLD MAX10 as the clock source in my system. The minimum clock frequency that the oscillator can output is 55MHz (it's a 10M08), which is too high for me (I need a clock that is less than 50MHz), so I let it go through a PLL. osc osc_inst ( // Internal oscillator
.oscena ( 1'b1 ),
.clkout ( in_clk )
pll_mod pll_mod_inst ( // PLL
.areset ( sys_rst ),
.inclk0 ( in_clk ),
.c0 ( clk ),
.locked ( pll_locked )
); And I got an error 15065: error (15065): clock input port inclk[0] of pll "pll_mod:pll_mod_inst|altpll:altpll_component|pll_mod_altpll:auto_generated|pll1" must be driven by a non-inverted input pin or another pll, optionally through a clock control block I have tried to go through a clock control block (ALTCLKCTRL) before going into PLL too, but still got the same error. Can anyone help me with this? Thanks.1 Reply
in the "MAX 10 Clocking and PLL User Guide"
section 3-2 "Internal Oscillator Design Considerations" "You cannot drive the PLLs with internal oscillator." i think that is the reason. integrate a oscillator in a fpga is a great progress, but if it can not be connected to a pll, the internal oscillator can not be used in most case. i do not know why
