10 years agoCouple of questions about the remote update system
Hello! This is my first time around this forums, so greetings to all of you. I hope you can help me with the following questions. I've been tasked with implementing the remote update functio...
10 years ago1) No, Your hardware has not been implemented using hardcore, so they could be affected by SEUs. Even if you utilize a hardcore, its configuration can be affected by SEU.
5) Your configuration determines the purpose of the CRC related pins. You can configure them for your requirement. You should be aware of the board, you are configuring. You cannot check which pin is used for which purpose unless you know the board connectivity.
