15 years ago
correct writing style
What is the correct writing style: "if (a='1' and b='0' and…… z='1') then idan<='1'; or : "if (a& b&C&…..Z)= x"8038" then idan<='1'; ?
What will require less logic elements?
Idan
    I think second one is logically more easy.
    Because for the first expression,"a==1",that means comparator is needed which can compare "a" with value "1" everytime.And same for other variables,
    so comparator hardware will be implemented.
    While in second one,all ANDing operation will be done,if true then body will be executed.
    Though second one seems logically more easy but quartus hardware will be same for both the code.
    which langguage are you talking about?
    but either way, they will produce the same number of logic elements, because its the same thing.
    And choce whatever style you think is more readable.
