15 years agoCorrect Arria II GX ALTGX Reset Sequence?
I have designed a reset controller for my ALTGX-based PIPE interface per The Arria II GX handbook, Vol2 page 4-16. My goal is to be able to capture the PCIe compliance pattern sent out by a PC mother...
15 years agoWe just had an Altera transceiver specialist in this last week and his recommendation with respect to resets was that rx_digital_reset should only be released after rx_freqlocked has remained high for 4us. In my opinion this is not very clear in the sequence diagrams but if you signaltap the pins you can see that rx_freqlocked toggles for a while once it goes active. The Altera guy said that it rx_freqlocked to be continuously asserted for 4us before releasing rx_digital_reset.
There's also a specific reset sequence for PCIe functional mode http://www.altera.com/literature/handbooks/wwhelp/wwhimpl/js/html/wwhelp.htm#href=stx4_siv52004.21.3.html That was for stratix iv but maybe something similar for the ArriaII part?
