18 years agoCopying code from EPCS to MRAM
Hello, I have a board with Stratix II and EPCS16. EPCS16 has plenty of space left over the configuration data for the FPGA (EP2S30). This space can probably be used for storing code for the em...
18 years agoAdditionally, you don't need to limit yourself to just one (onchip) memory. While dicing your code up amongst multiple memories does add complexity, it is possible, and should be considered if cost is a concern. See the relevant documentation with respect to custom linker scripts to find out more about this option.
You'll find that the "auto" option doesn't magically span multiple memory types. Cheers and Good Luck!
