18 years agoCopying code from EPCS to MRAM
Hello, I have a board with Stratix II and EPCS16. EPCS16 has plenty of space left over the configuration data for the FPGA (EP2S30). This space can probably be used for storing code for the em...
18 years agoWith "Block type" set to "Auto", Quartus should use MRAM and other RAM block types as needed without your using LogicLock. My LogicLock suggestion was just in case you specifically wanted MRAM and M4K together as mentioned in your first post but for some reason wanted not to use M512.
