18 years agoCopying code from EPCS to MRAM
Hello, I have a board with Stratix II and EPCS16. EPCS16 has plenty of space left over the configuration data for the FPGA (EP2S30). This space can probably be used for storing code for the em...
18 years agouraslacker: thanks
Brad, What I need is as much on-chip program memory as possible for my application. Each MRAM block is 512 Kbit (64 KB). So if I use an FPGA with more than one MRAM, for example EP2S60 with 2 MRAMs, they will be combined to form a 128 KB memory But if my FPGA only has one MRAM (EP2S30) - I want to still have more program memory by combining it with M4Ks or M512. If I understand you correctly, the only way to do this is with LogicLock ?
