10 years agoConverting .sof and .elf to make single .pof
Hi Everybody, I am in the process of buying Licence for IP Which I used in my program. Till now I am testing my program with time_limited.sof file for FPGA and .elf file for NIOSII and It ...
10 years agoThere is not any way to do this from within Quartus.
The first thing to fix would be nios2-elf-objcopy not producing any output .hex file. If your post is accurate, it looks like you're not invoking the command properly? Here is the command I use from my scripts:
nios2-elf-objcopy --input-target srec --output-target ihex ${ELFFILE}.srec ${HEXFILE}
i.e. GNU-style double-dash "--" argument prefixes.
