15 years agoControlling Burst Mode in software
Hi. I have a verilog module that buffers a considerable amount of samples and when the buffer gets full id like to empty the buffer using a Nios processor for some computations. Using single IOR istr...
15 years agoThe only bursting that Nios can directly perform is when using a code or data memory cache. To move data between two slave components using bursting you can use a DMA controller. When writing your own custom components you could also consider including a bursting Avalon master in your component.
