18 years agoControl Of Automatic Vehicle wash m/c
hi I have started working on the project "Control Of Automatic Vehicle wash m/c using FPGA". I have started working on the VHDL programming now taking reference of the older PLC programmes. H...
18 years agothe voltage levels are the important thing with io's because you'll be dealing with heavy machinery like motors and stuff. So you'll be needing a interface like a voltage converter... also check the current ratings of the equipment cuz you can't afford to have your device damaged. The resources available on a CPLD may fit you needs but it might fall short when it comes to io's...
