10 years agoConstrainst for data launched by negative edge
Hi, What is the correct way to constrains source synchronous inputs in this case:External device provides clock with data. External device launches data on falling edge. FPGA latches dat...
10 years ago --- Quote Start --- Hi, Thanks for reply kaz. So as I understand you are saying that multicycle is not needed in my case, since data is sampled at same clock period? What do you mean by saying: . How it can be modified? --- Quote End --- if your tCO is 7 ns relative to falling edge and clk period is 20 ns then it means it is 3ns from next rising edge --- Quote Start --- So what to do next? Clock relationship seems to be correct by looking at TimeQuest waveform, but timing requirements are not met. Am I using tCO values for max/min delays in a wrong way or am I missing something else? Thanks --- Quote End --- tCO min of 0 and tCO max of 7 gives 7 ns window of transition. This is a bit wide. I suspect tCO min to be closer to 7 than zero.
