13 years agoconstraining push button input using TimeQuest
Dear All, have a push-button input to one of the pins in the FPGA. This passes through 2 flip-flops to get into FPGA clock domain. How can I specify this correctly in the TimeQuest? I do not wa...
13 years agoYour input isn't constrained until you put a set_input_delay constraint on it(or set_max/min_delay). Until you've constrained it, set_false_path doesn't do anything to the design. So no, you don't have to.
Now, there is an Unconstrained Paths report that tells you what ports don't have constraints. Your push-button would show up here, and so sometimes people put a set_false_path assignment on it just to get it off this report. It has no effect on the actual design, but can help the design process(e.g. managing which ports still need constraints).
