13 years agoConstrain SDR and DDR interface on the same interface
Hello, I have an IC that is outputting a databus with a center aligned clock. Depending on its mode, it is outputting in single data rate (up to 200MHz) or in dual data rate (up to 100MHz). ...
13 years agoThe falling edge registers are indeed ignored in SDR mode.
I was wrong in my post, I do use the -waveform but on the clock coming into the FPGA. Thus using option 2. Thanks for making things clear to me!
