18 years agoConnecting unused pins
Hello everyone, I have a design using a Cyclone III, with some unused pins. I wonder what would be the best recommendation about what to do with these pins. By default Quartus reserve these p...
18 years agoGenerally I set unused pins to"output driving ground".
Be totally sure that the unused pins are not connected to VCC or external logic on your PCB! Ground bounce reduction is always a good thing and the extra "GND" pins can help with noise imunity when routing. Setting unsued pins to "input tri-stated" ensures that you will not have contention with external devices so can be of use. Personally, I wouldn't go down the route of drivings logic '1' from your device and using pull-ups to VCC.
