17 years agoconnecting be_n_to_the_ext_ssram[3:0] to IDT71V416 SRAM
Hello all, I created using SOPC builder a NIOS II based system that includes an SRAM compatible with IDT71V416 listed in SOPC builder, for the SRAM, I added an IDT71V416 from Memories and Memo...
17 years agoI generated an SOPC system using the custom 16 bit SRAM controller sram_256Kx16bit_hw.tcl
result:the SRAM address width was generated as 19 bits wide although the IDT71V416 (ISSI IS61WV25616BLL) has only 18 bits as seen below from the NIOSII_system module definition of the address to the external SRAM output [ 18: 0] address_to_the_ext_sram_256Kx16bit; what is the best action to take to connect the 18 bit SRAM address lines thanks js
