15 years agoconfiguring multiple fpga's with multiple bitstreams via JTAG connection.
Hello People, I have successfully developped a special board with six fpga's (EP3C25) each fpga has its own EPCS16 configuration memory and they are programmed seperately on their own JTAG sock...
15 years ago --- Quote Start --- How many buffers should be used here? on the handbook there is only two Cyclone III devices and there is a buffer between the devices. But should we put additional buffers if there are more than two devices? i mean, one buffer after each device? --- Quote End --- Generally for clocks you want point-to-point routes on a PCB. Most buffers can drive a couple of source-terminated loads, so one buffer can be used to generate a couple of TCK and TMS fanouts. Take a look at the CARMA board design that I posted links to, look in the schematic: http://www.ovro.caltech.edu/~dwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf) Page 7 has the JTAG high-level diagram. p44 has the Altera JTAG buffers. Note how the buffers have series terminations on their output - this is so that one buffer can drive multiple TCK and TMS traces. p77 shows some more buffering with dual-source terminations. p78 shows the inter-FPGA JTAG TDI/TDO chains. Since the I/O levels are 2.5V, the FPGAs can be connected directly. If the FPGA TDO driver was being powered from an I/O bank voltage of 1.8V, then a 1.8V-to-2.5V (or 3.3V) level translation buffer would be required when buffering between FPGAs. I have a buffer on the CEO# signal so that a red LED is turned off once the FPGAs are configured. This is nice for debugging. Cheers, Dave
