15 years agoconfiguring multiple fpga's with multiple bitstreams via JTAG connection.
Hello People, I have successfully developped a special board with six fpga's (EP3C25) each fpga has its own EPCS16 configuration memory and they are programmed seperately on their own JTAG sock...
15 years agoThanks brothers, i am an "Altera Pupil" and have lots of things to learn from you.
With your advises, i have focused on Passive Serial (PS) method. and i have some more questions; 1- What part can be used for serial flash memory ic? EPCS again? or more economic parts available? (i will need to memorize 6 seperate bitstreams (for cycloneIII - 25K) inside). 2- is the buffer really needed? i will have 6 or 8 fpgas on the chain. if needed, which parts can you advise me? 3- i will need to update the bitstreams in the memory ic. but the ic's data output is connected directly to the fpgas and no connection exists to the mcu. can i simply put a resistor on the existing line and connect the mcu directly before the resistor on the line? or how? Regards...
