18 years agoConfigure Cyclone with Flash and PIC
Hi @ all! Has anyone tried to configure Cyclone on bootup wit a simple 8-Bit-µC? Is there an example available ? I've seen some posts in different forums about a CPLD-solution, but no ex...
18 years agoFor a Cyclone EP1C20, the config file size is 3.56 M-bits.
The maximum DCLK frequency Cyclone supports is 66 MHz; so 1/66M * 3.56 M-bit = 54ms This does not take into account any overhead in the code, as well as the fact that your 8-bit micro probably can't toggle it's GPIO at 66 MHz..... Hope this helps.
