15 years ago
Configure Cyclone II
Hi !!!
i want to configure a cyclone II in AS mode with a microcontroller which is connected to a SPI flash and cyclone II too. So my question is : When you put nConfig low, every pin of FPGA are they in high Z ??
Thanks in advance
    Thanks for your answer i think it's the solution, but i have an other question about that if i deassert nCE what's the state of the other pin like nConfig, nStatus, ASDO or DCLK ??
    --- Quote Start ---
    --- Quote End ---
    Not every pin. If you want to access the AS configuration memory by the processor, you need do deassert nCE.
    During the configuration the I/O pins are set up as inputs with weak pull-up to their respective VCCIO.
