SLeit
7 years agoConfiguration problem under low temperature at 10M04SAE144I7G
the Configuration work well at room temperature when we goes down to 10 Celsius degree and down to - 20 Celsius and turn on the board voltage the device no get the configuration
SLeit
7 years agoDear YL
- can we send the FPGA board schematic for review ?
- can you let me know what is the device configuration that we should set, we did set without nSTATUS, nCONFIG, CONF_DONE. pins - what is the correct setup for this IC ?
Thank you in advance
Shraga
