15 years agoConfiguration CyclonIV with 2.5V and EPCS with 3.3V
I have a question about the configuration of a Cyclon IV with a EPCS in AS mode. The problem is, that I use the LVDS ports of bank 1/2, so I have to supply these banks with 2.5V. The configuration pins are also on the first bank. The configuration device EPCS must be supplied with 3.3V. So the I/O voltage of the configuration device is about Vs-0.3V. The question: Is it possible to connect the configuration pins of FPGA and EPCS, without any protection? (The internal clamp diode is not availible for the configuration pins)2 Replies
Thank you, for the fast response.
Altera suggests a series resistor at EPCS data ouput to reduce overshoots. There will be no problems when driving a 2.5V bank from 3.3V logic, as long as no severe overshoots are generated. According to specified in- and output levels, the problem is in driving a 3.3V CMOS device with a 2.5 V I/O standard. See the I/O standard matrix in Cyclone IV device manual.
See this recent discussion http://www.alteraforum.com/forum/showthread.php?t=31810
