15 years agoComputer vision
I'm working on a machine vision project where I have a high data rate (>100 MB/s) to process. The camera will be connected to the system using either GigE vision or CameraLink protocol, and let's ass...
15 years agoThank you Tricky for advice. I've started learning about digital hardware design and VHDL since your post. It's building up little by little.
Can someone please tell me more about NIOS II? From the product literature that I've read, I understand that it is a soft microprocessor that can be implemented on Altera boards and I can use C to code things on it. Is it that simple?? What are the drawbacks of using the soft embedded microprocessor?
