15 years agocompression option
i am using the FPP configuration scheme with MAXII & a flash device i need to switch now to FPP with compression. do i need to change the MSEL pin settings? or can i just program the FLASH wit...
15 years agoAs far as I know, most of FPGA does require the MSEL change. However, some of devices does not...
For example Cyclon* does not require MSEL change. Stratix* will require MSEL change. Check the configuration document on the Altera website.
