15 years agoCompling error
Hello I have had this error show up several times. it is a subscription version of Quartus 9.1 with both service packs installed. I thought the service packs would fix the problem but alas I was wrong. Any ideas what might be causing this one?
Warning: FLEXlm software error: User/host not on INCLUDE list for feature Feature: quartus License path: FLEXlm error: -39,147 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com". Error: Current license file does not support the EP3C40F484C6 device Error: Peak virtual memory: 209 megabytes Error: Processing ended: Fri Aug 12 08:04:08 2011 Error: Elapsed time: 00:00:04 Error: Total CPU time (on all processors): 00:00:03 Thanks2 Replies
do you get this error in every compile or randomly?
you can set up a license server to restrict access to certain users (or apparently hosts). my guess is that your user/host is not enabled, as explained in the error message - Altera_Forum
Have you tried another version of quartus?
