15 years agocompile error:Can't generate netlist output files
There have a problem: when I compile a project, shows an Error: Can't generate netlist output files because the license for encrypted file "C:/altera/72/ip/fir_compiler/lib/msft_lt_32.v" is not available. What's the meaning? Thanks for your help!~2 Replies
Thanks for your reply! I got it.
You basically have a piece of IP that is encrypted and requires a license file to use in your design.
If it's and old design, see if you can find the original Altera license file. It may have a perpetual license, that just isn't in your new license file. If not, contact your Altera rep about getting a license file. Pete
