15 years agocompilation report in Quartus
Hi, Can anyone tell me how can I display the details of compilation report? After done write the VHDL code and compile it, I want to display the report in terms of area and maximum frequency....
15 years ago --- Quote Start --- Hi pletz, I want both of them..thanks for reply --- Quote End --- Hi, the results of the timing analysis shows you how fast your design could run. Important is that you specify reasonable timing constraints. The number of clock cycles for your processing must be calculated by yourself. Kind regards GPK
