15 years ago
compilation report in Quartus
Can anyone tell me how can I display the details of compilation report?
After done write the VHDL code and compile it, I want to display the report in terms of area and maximum frequency. How can I do that..help me please
Many thanks
    Hi pletz,
    power calculator?..Okay, I try study on that. Many thanks pletz =)
    --- Quote Start ---
    Hi pletz,
    How about the power consumption?..Thanks for reply
    --- Quote End ---
    HI,
    I know there is a power calculator build-in in Quartus, but I have no experience
    using it.
    Kind regards
    GPK
    Hi pletz,
    --- Quote Start ---
    Hi pletz,
    I want both of them..thanks for reply
    --- Quote End ---
    the results of the timing analysis shows you how fast your design could run. Important
    is that you specify reasonable timing constraints.
    The number of clock cycles for your processing must be calculated by yourself.
    Kind regards
    GPK
    --- Quote Start ---
    Hi pletz,
    Can I observe the latency and throughput also? thanks for reply..
    --- Quote End ---
    what did you mean with latencey and throughput ? The clock speed of your design or the
    number of clock cycles your processing need ?
    Kind regards
    GPK
    Hi pletz,
    --- Quote Start ---
    Many thanks
    --- Quote End ---
    a short overview of the resource uitilization you can found by selection of the "Flow summary" page.
    For timing info's you have to open the "TimeQuest Timing Analyzer" section in the compilation report.
    Kind regards
    GPK
