17 years agocompilation for 163 bits
hi to al! the compilation for 163 bits (2 inputs of 163 bits each and the output is also 163 bits) is not exceeding 2% of full compilation and 9% of analysis and synthesis even when the time ha...
17 years ago --- Quote Start --- that particular loop runs 652 times for each function call.. to be exact..the loop is carried out 163*163*653 times totally. --- Quote End --- Yes, you're right, it's even worse then I thought, I didn't see the two outer loops. A HDL loop doesn't simply run like a C-Program loop. Each iteration creates new hardware. I simply doesn't work.
