17 years agocompilation for 163 bits
hi to al! the compilation for 163 bits (2 inputs of 163 bits each and the output is also 163 bits) is not exceeding 2% of full compilation and 9% of analysis and synthesis even when the time ha...
17 years agoAs you have mentioned , that particular loop runs 652 times for each function call.. to be exact..the loop is carried out 163*163*653 times totally. if i want to reduce this constrain, could i go for the case statement where i can assign the values at first itself instead of running the loop for generating the j(n) values??
secondly, i have made corrections to match the integer size and the array size by changing the size of array to 32. now also my code is stuck..its running for more than one hour without crossing the 2 % of full compilation. could there be any other prob?
