17 years agocompilation for 163 bits
hi to al! the compilation for 163 bits (2 inputs of 163 bits each and the output is also 163 bits) is not exceeding 2% of full compilation and 9% of analysis and synthesis even when the time ha...
17 years agoThe code for 163 bits is the following one:
module newconv(c,a,b); parameter N=162; input [0:N]a,b; output [0:N]c; reg [0:N]c; reg [0:N]d,e; integer k; reg y; always @(a or b) begin d=a; e=b; for(k=0;k<N+1;k=k+1) begin //$display("d=%b,e=%b",d,e); y=F(d,e); c[k]= y; d=SO(d); e=SO(e); end end function F; input [0:N]u,v; integer k; integer o,p; begin F=0; for (k=1; k<652; k=k+1) begin o=j(k+1); p=j(k); F= F^(u[p]&v[o]); //$display("k=%d, o=%d, p=%d, u=%b, v=%b, f=%b",k,o,p,u[p],v[o],F); end end endfunction function[0:16]j; input [0:16]k; parameter m=163; parameter T=4; parameter U=149; parameter p=653; reg [0:16]J[0:652]; //integer n,w,m,T,U,p; integer n,i,l,w; begin w=1; for (l=0; l<T; l=l+1) begin n=w; for (i=0; i<m; i=i+1) begin J[n]=i; n=(2*n)%p; end w=(U*w)%p; end j=J[k]; end endfunction function [0:N]SO; input [0:N]SI; reg [0:N] tmp; begin tmp = SI; tmp = tmp<<1; tmp[N] = SI[0]; SO = tmp; end endfunction endmodule this the code for 7 bits but with the parameters changed. could u possibly tel me the sol to this compilation prob?
