14 years agoCompact FLash UDMA Mode Problem
Hello, I'm designing a board with EP2S30 and a compact flash as a compact flash reader board. FPGA drives the Compact Flash pins. Pins are set as LVCMOS and weak pull ups enabled in data pin...
13 years agohello,eakdemir
I used an EP3C25Q to read a sandisk extreme CF card by UDMA, but the CF card pin42 also the IO_RDY signal is always low, and reading from the CF, there is only the first word and the DSTROBE didn't change ever, I think there may be something wrong with the pin42 or any configuration needed to use the UDMA, could you give me some advice. thanks https://www.alteraforum.com/forum/attachment.php?attachmentid=6463
