10 years agoCommercial/Industrial Temperature FPGA - Using Same Configuration
Hi there, Do you happen somebody to know what would be the effect if using FPGA configuration, synthesized for commercial grade device, on industrial one, i.e. EP2C8Q208C8N conig on a EP2C8Q208...
10 years ago --- Quote Start --- If you don't want to resynthesize it is possible to run a TimeQuest analysis on a different grade and different temperatures. Have a look at the documentation for the set_operating_conditions tcl command in Timequest. That way you can know if your compiled design can be safely run on a different grade. AFAIK Quartus by default compiles for the worst conditions, i.e. slowest timing in the grade you specified for setup requirements and highest timing in the whole grade range for hold requirements. So you should be safe. --- Quote End --- I did try the set_operating_conditions with "-grade i" option. However, TimeQuest reports that the command is illegal for this device. Only "-grade c" is accepted. Thanks, Victor
