10 years agoCommercial/Industrial Temperature FPGA - Using Same Configuration
Hi there, Do you happen somebody to know what would be the effect if using FPGA configuration, synthesized for commercial grade device, on industrial one, i.e. EP2C8Q208C8N conig on a EP2C8Q208...
10 years agoThat will be fine. For -8 parts there are very few timing parameters that differ between the commercial and industrial parts - it's principally the operating temperature range that distinguishes them. In each case where there is a difference between the timing parameters, the industrial grade part has tighter timing. So, the industrial part should meet timing.
Regards, Alex
