14 years agoclock synchronization problem
Hi Everyone, Please I need help
I am designing speech recognition system on DE2 board. I generated some Megafunction modules in Quartus II such as: [32_bits LPM shiftreg] -- to convert from serial to parallel and vice versa, [32_bits ALTFP] -- to convert from integer to float and vice versa, I instantiate those four modules together as -------------------- ------------- ------------- ------------------- - serial2parallel - -----> - int2float - -------> - float2int - --------> - parallel2serial- -------------------- ------------- ------------- ------------------- My question is which clock should I use to drive speech data through those modules, I used 50MHZ but I got noisy signal in the output(speakers).No RepliesBe the first to reply
