18 years agoClock skew problem
Hello, I am actually facing problems related to clock skew. Timing analisys reports a clock skew problem between the output of a latch and an input of a register( 40 bit wide bus ). I h...
18 years agoSorry for the late reply... I have been busy with some other stupid stuff.
Anyway, I am back to the problem , which is solved now, thanks to you guys. I followed the recommandation from Rysc, and indeed it working perfeclty, as I have no uge timing constraints ( just a speed loss of 2.5%,after turning on the hold time optimization ). Thanks Brad for the link to the ripple and gated clock, I found it very interesting. Cheers
