18 years agoClock skew problem
Hello, I am actually facing problems related to clock skew. Timing analisys reports a clock skew problem between the output of a latch and an input of a register( 40 bit wide bus ). I h...
18 years ago --- Quote Start --- ... it's recommended to not gate clocks from the beginning. If the gated clock could be changed to a clock enable or something like that, then the structure is better from a good design practice standpoint. --- Quote End --- For more about this, see http://www.alteraforum.com/forum/showthread.php?t=2388.
