15 years agoclock divider
Hi, how can I divide the 50 mhz clk to 33.2 mhz clk in vhdl code?
15 years agoI second Kaz on this, with a minor modification. I have always used a modulo counter for clock division. So you can use a counter to count the cycles, thus increase it by one each cycle, and once a value is reached, set the clock high. In this way you won't need the adder and subtractor in Kaz's code (incrementor is cheaper in terms of HW).
