12 years agoClassic DMA core speed?
Hi everybody, Please allow me one silly question. Let me explain small problem. I have one DMA inside Qsys, 1x 16bit PIO, SDRAM controller (16bit databus width). All peripherials are running at...
12 years ago --- Quote Start --- Hi Jan: The DMA core basically just allows you to initiate a transaction of a specific size to a specific location with minimal CPU overhead. The latency required for the transaction is dependent upon many factors, include arbitration cycles, ram paging etc. A 2 to 1 ratio sounds very reasonable. This is much faster than A CPU would be able to copy the bytes to the memory via instructions. If you truly need a 1 to 1 for a limited number of cycles, put it into a fifo or TCM (Tightly Coupled Memory). Pete --- Quote End --- Thanks for the answer... When I was studying about TCM I have read that it is possibile to use only with the internal onchip slave... so I think that my external SDRAM is not capable of TCM.. Am I right? So only what I can do is to increase the Fclk to the top of the SDRAM possibilities to drag even more speed from DMA? Thanks for advice
