15 years agoChanging drive strength
We need to change the drive strength on our Cyclone FPGA. I want to know how to do it. Is it a change in the code or is it as simple as selecting the desried drive strength from a drop down...
15 years agoIn the QSF :
set_instance_assignment -name CURRENT_STRENGTH_NEW "MAXIMUM CURRENT" -to arria_dq Or, in the assignment editor, choose the "Current Strength" assignment, then it has a drop down box for different values you may assign, although depending on your voltage level they may not all be valid assignments.
