8 years agoChange Quartus project IP search path
Hi, I am trying to add a HLS created IP into the design. For this I am updating the quartus project IP path in platform designer. I am getting the following error. Error: An unexpected e...
8 years agoHi,
If still facing the problem. Try by opening HLS count project which will add the path automatically so that no need to set it manually. or 1.If you are using Pro version and want to add the directory manually than point till the "components" under global ip search directory it will take the sub-directory and other files automatically. 2.If you are using Std version and want to add the directory manually than point till the "count" under global ip search directory it will take the sub-directory and other files automatically. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/hls/ug-hls.pdf Let me know if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
